NBA2king CFB 26 Coins: Know Your Running Schemes
Добавлено: 22 ноя 2025, 02:57
Before you can excel on CFB 26 Coins the ground, you must understand the different running concepts. College Football 26 features an impressive variety of run schemes, each with unique strengths, weaknesses, and timing demands.
1. Inside Zone – The Bread and Butter
The inside zone is one of the most reliable and balanced plays in football. It relies on zone blocking, where offensive linemen move laterally and block areas, not specific defenders.
How it works:
The running back reads the first defensive lineman past the center. If that lineman gets sealed, cut inside. If not, bounce outside. The play’s success depends on reading leverage and patience—don’t sprint immediately; let the blocks develop.
Best used against: Even fronts and blitz-heavy defenses.
2. Outside Zone – Speed to the Edge
The outside zone (or stretch run) aims to reach the perimeter and exploit defensive overpursuit.
How it works:
Your linemen move laterally, sealing defenders to the inside. The RB follows the flow, looking for a cutback lane. The key is acceleration—once a crease opens, hit it hard.
Best used against: Slow linebackers or defensive lines that lack lateral quickness.
3. Power Run – Smashmouth Football
The power run is all about gap blocking—linemen create holes through double-teams and pulling guards.
How it works:
A pulling guard or tackle kicks out the edge defender while the fullback or tight end leads through the hole. The RB follows the blocks with decisive cuts.
Best used against: Light defensive fronts and spread-out formations.
4. Counter Play – Misdirection Mastery
Counters look like one direction but hit the other, baiting linebackers into overcommitting.
How it works:
The offensive line fakes zone blocking to one side while the RB takes a delayed step before cutting back. The pulling lineman leads through the backside gap.
Best used against: Aggressive defenses and blitz-heavy playcallers.
5. Read Option – Control the Defender
The read option remains one of the most dynamic plays in College Football 26. It allows your QB to decide mid-play whether to hand off or keep the ball.
How it works:
You read the unblocked edge defender. If he crashes toward the running back, keep the ball with the QB. If he stays wide, hand it off.
Best used against: Man coverage and defensive lines that overcommit to buy NCAA 26 Coins the run.
How it works:
How it works:
How it works:
How it works:
How it works:
